Upgrade to Premium
Reply
  #1
Old 08-16-2010, 04:59 AM
arfrce arfrce is offline
Currently: Not set.
Basic Member
arfrce has a reputation beyond reputearfrce has a reputation beyond reputearfrce has a reputation beyond reputearfrce has a reputation beyond reputearfrce has a reputation beyond reputearfrce has a reputation beyond reputearfrce has a reputation beyond reputearfrce has a reputation beyond reputearfrce has a reputation beyond reputearfrce has a reputation beyond reputearfrce has a reputation beyond repute
Default TOP 10 things to do before you RIDE !!!!
Ok Guys an Gals Let's hear the first 10 things you do before you get ready to ride. This is a serious thread. To help out anyone that doesn't know how to prepair their sled for the upcoming season.
Thanks,
Sledders.
Rate this post: Yes | No
The Following 2 Users Say Thank You to arfrce For This Useful Post:
aksnomachinechic (11-05-2010), justinkredible56 (08-16-2010)
  #2
Old 08-16-2010, 10:57 AM
justinkredible56's Avatar
justinkredible56 justinkredible56 is online now
Currently: 555lb ready to ride Nytro!
justinkredible56 has a reputation beyond reputejustinkredible56 has a reputation beyond reputejustinkredible56 has a reputation beyond reputejustinkredible56 has a reputation beyond reputejustinkredible56 has a reputation beyond reputejustinkredible56 has a reputation beyond reputejustinkredible56 has a reputation beyond reputejustinkredible56 has a reputation beyond reputejustinkredible56 has a reputation beyond reputejustinkredible56 has a reputation beyond reputejustinkredible56 has a reputation beyond repute
Default
1. Clean the clutches
2. Grease EVERYTHING
3. Check Driveshaft Bearings
4. Check Track tension
5. Change Chaincase Oil
6. Check Tension on the Chaincase chain (haven't busted into the nytro's chaincase yet so I don't know if it has an automatic tension mechanism)
7. Change the motor oil.
8. Check Coolant Level.
9. Change spark plugs (optional-probably every other season on 4 strokes)
10. Check Cylinder compression
11. Check your Hifax for wear, I haven't witnessed it but I hear it's a big concern on the nytro.
That's what I usually do but I love the thread Idea, keep the lists coming.
-Justin
The Following 3 Users Say Thank You to justinkredible56 For This Useful Post:
aksnomachinechic (11-05-2010), arfrce (08-24-2010), christopher (08-24-2010)
  #3
Old 08-24-2010, 11:20 AM
Currently: Not set.
Basic Member
Default
That's great. Thanks for the reply. If anyone thinks of anything else please toss it in there.
I hope this helps out some of the newer members.
Thanks
Come on give it up to justinkredible56 for this very useful info
  #4
Old 08-24-2010, 07:22 PM
MRFUSION MRFUSION is offline
Currently: Not set.
MRFUSION has a reputation beyond reputeMRFUSION has a reputation beyond reputeMRFUSION has a reputation beyond reputeMRFUSION has a reputation beyond reputeMRFUSION has a reputation beyond reputeMRFUSION has a reputation beyond reputeMRFUSION has a reputation beyond reputeMRFUSION has a reputation beyond reputeMRFUSION has a reputation beyond reputeMRFUSION has a reputation beyond reputeMRFUSION has a reputation beyond repute
Default
I always make sure your 4 rear skid mount bolts are loctited and secure. Seen one bolt fall out either destroying the hole or worse. Pretty hard to to tow out too.
Shad
__________________
Strait up ready for Bangin
The Following User Says Thank You to MRFUSION For This Useful Post:
  #5
Old 08-24-2010, 08:24 PM
MTN_VIPER's Avatar
MTN_VIPER MTN_VIPER is online now
Currently: Making roll-over valve kits since 2008
MTN_VIPER has a reputation beyond reputeMTN_VIPER has a reputation beyond reputeMTN_VIPER has a reputation beyond reputeMTN_VIPER has a reputation beyond reputeMTN_VIPER has a reputation beyond reputeMTN_VIPER has a reputation beyond reputeMTN_VIPER has a reputation beyond reputeMTN_VIPER has a reputation beyond reputeMTN_VIPER has a reputation beyond reputeMTN_VIPER has a reputation beyond reputeMTN_VIPER has a reputation beyond repute
Default
Jack the front of the sled up, and check for wear/slop in the ball joints, tie rods, A arm bushings, spindle bushings.
Check ski wear bars and ski condition while your there.
Loosen the track and check boggie wheels/bearings, they should spin nice and free with no roughness or noise. For the rear axle wheels, it's usually easier to pull the wheel, or skid out.
When re-adjusting the track tension, don't forget to check the track alignment. I usually put the sled on a track stand, then spin it up to about 15-20 mph and then let it coast to a stop. The track drive lugs should have the same distance to the rail on each side.
Put new batteries in the beacons, test them, and take an avy refresher course.
__________________
Four Stroke Solutions LLC
Patented Roll-Over Valve Systems
ROV kits for M/XF7000/Viper, Sidewinder and King Cat with Quick-prime!
For Arctic Cat and Yamaha Sleds
Patents 8,225,766 8,528,516 9,303,537
http://fourstrokesolutionsllc.webs.com/
e-mail fourstrokesolutionsllc@hotmail.com
The Following 2 Users Say Thank You to MTN_VIPER For This Useful Post:
aksnomachinechic (11-05-2010), christopher (08-24-2010)
  #6
Old 08-24-2010, 10:01 PM
ruffryder's Avatar
ruffryder ruffryder is offline
Currently: Not set.
ruffryder has disabled reputation
Default
I agree with everything except the above. It is a yamaha, it is all junk there, and ignorance is bliss and cheaper on the wallet. ha ha
  #7
Old 08-25-2010, 12:41 AM
irondave86's Avatar
irondave86 irondave86 is offline
Currently: Not set.
irondave86 has a reputation beyond reputeirondave86 has a reputation beyond reputeirondave86 has a reputation beyond reputeirondave86 has a reputation beyond reputeirondave86 has a reputation beyond reputeirondave86 has a reputation beyond reputeirondave86 has a reputation beyond reputeirondave86 has a reputation beyond reputeirondave86 has a reputation beyond reputeirondave86 has a reputation beyond reputeirondave86 has a reputation beyond repute
Default
I agree with ruffy, I don't need to check the front end on my nytro to know it's toast........
__________________
Boosted 08 Nytro MTX 40th
  #8
Old 10-25-2011, 05:21 PM
Mister907 Mister907 is offline
Currently: waitin to ride...again
Mister907 has a reputation beyond reputeMister907 has a reputation beyond reputeMister907 has a reputation beyond reputeMister907 has a reputation beyond reputeMister907 has a reputation beyond reputeMister907 has a reputation beyond reputeMister907 has a reputation beyond reputeMister907 has a reputation beyond reputeMister907 has a reputation beyond reputeMister907 has a reputation beyond reputeMister907 has a reputation beyond repute
Default
Dont forget the gas.
fix as much as possible
  #9
Old 03-14-2012, 07:22 PM
wilmot wilmot is offline
Currently: waiting for winter
wilmot has a reputation beyond reputewilmot has a reputation beyond reputewilmot has a reputation beyond reputewilmot has a reputation beyond reputewilmot has a reputation beyond reputewilmot has a reputation beyond reputewilmot has a reputation beyond reputewilmot has a reputation beyond reputewilmot has a reputation beyond reputewilmot has a reputation beyond reputewilmot has a reputation beyond repute
Default
Make sure you change batteries in beacon and radio and pray for lots of powder
  #10
Old 11-02-2012, 09:04 PM
cbc24 cbc24 is offline
Currently: IG: crozierc
cbc24 has a reputation beyond reputecbc24 has a reputation beyond reputecbc24 has a reputation beyond reputecbc24 has a reputation beyond reputecbc24 has a reputation beyond reputecbc24 has a reputation beyond reputecbc24 has a reputation beyond reputecbc24 has a reputation beyond reputecbc24 has a reputation beyond reputecbc24 has a reputation beyond reputecbc24 has a reputation beyond repute
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
no new posts
