I have an 03 ZX 800 HO, I noticed today that there is an extremely large amount of oil across the front of the engine, and even more on the inside of the clutch/belt cover. pulleys and belt are soaked. I pulled the primary off and saw that the crank seal was actually crooked. As in one side of the seal is out by about 1/16''. I do not know definitively that this is the source of the leak. Seemed to make since at first, but i started it up and sprayed everything with carb spray and it did not change the idle at all. I had to replace my cables this year, and I know that the pump is giving too much oil (though i have the cable adjusted to proper specs per the manual). So i guess my question is, can oil leak from the crank seal? Is there some other failure that would cause the crank seal to be forced out? or was it likely installed wrong by the factory or previous owner? (there is no noticeable crankshaft end-play) Obviously i will be replacing the seal, and re-adjusting the oil pump. Anyone ever hear of such a problem? The sled runs great, other than i did have what seemed to be a loss of RPM/ power on a long climb in powder, but i figure that may be a product of oil soaked belt and clutches. Thanks in advance for any advice offered up!
