The reason slp says up the octane is because the pipe increases the rate of compression.
If you are at 0-3000 ft you want to for sure, if your in the deep at 3-6000ft then yes as well, from there it all depends how good of fuel map you have. I run 91 from 7-11000ft just because, there are few times I have had extreme under hood temps that could cause deto, so its just a saftey, Think of it this way at 10,000 ft you are loosing 1/3 of your hp, even with the slp pipe that drops you down around 130hp, less than stock, but you are running a little more rpm. I would think 87 would be fine as long as you don't get extreme heat under the hood. I'll stick with non-e 91 for now, but wont go over that. Thats with my m1000 anyway, if I had the det sensor I would prob run less.
