Just looking into many parts early season. talked with Dale at CPC and he will have adjustable s by November for the primary. Looks like early indications the cat and poo springs will work just not a perfect fit for the primary. The secondary looks to me to be a TSS 04 but not for sure. I would love to see a float for the secondary. It is a built on shaft secondary so i was wondering how you shim for alignment. also alignment bar part number and any info for weights and spring part numbers as the season works out is a PLUS. I plan to put the slp full pipe and pcv, this is my normal and i know how to clutch with the cat part just learning with the team stuff, any info would be well worth the help.
