Upgrade to Premium
Polaris: Pro-Ride 2010 and up, all models in the Pro-Ride chassis
Reply
  #1
Old 01-16-2019, 10:49 AM
Old Scud-doo's Avatar
Old Scud-doo Old Scud-doo is offline
Currently: Waiting for Feb. 23
Old Scud-doo has a reputation beyond reputeOld Scud-doo has a reputation beyond reputeOld Scud-doo has a reputation beyond reputeOld Scud-doo has a reputation beyond reputeOld Scud-doo has a reputation beyond reputeOld Scud-doo has a reputation beyond reputeOld Scud-doo has a reputation beyond reputeOld Scud-doo has a reputation beyond reputeOld Scud-doo has a reputation beyond reputeOld Scud-doo has a reputation beyond reputeOld Scud-doo has a reputation beyond repute
Default Stuck primary!
We have a 13' Pro at the dealer for a clutch rebuild and they can't get the primary off. Tried the water trick using water and even oil. Any body have any ideas?
__________________
[SIGPIC][/SIGPIC]
Rate this post: Yes | No
  #2
Old 01-16-2019, 01:50 PM
Always war's Avatar
Always war Always war is offline
Currently: Keeping it 90
Always war has a reputation beyond reputeAlways war has a reputation beyond reputeAlways war has a reputation beyond reputeAlways war has a reputation beyond reputeAlways war has a reputation beyond reputeAlways war has a reputation beyond reputeAlways war has a reputation beyond reputeAlways war has a reputation beyond reputeAlways war has a reputation beyond reputeAlways war has a reputation beyond reputeAlways war has a reputation beyond repute
Default
I’ve heard of guys filling it with water and leaving it outside over night, and waking up to it laying on the ground. That’s if it cold enough to do so.
__________________
If you don't live for something, you'll die for nothing.
The Following User Says Thank You to Always war For This Useful Post:
NO IQ (01-16-2019)
  #3
Old 01-16-2019, 02:08 PM
Teth-Air's Avatar
Teth-Air Teth-Air is offline
Currently: sourceinnovations.ca
Teth-Air has a reputation beyond reputeTeth-Air has a reputation beyond reputeTeth-Air has a reputation beyond reputeTeth-Air has a reputation beyond reputeTeth-Air has a reputation beyond reputeTeth-Air has a reputation beyond reputeTeth-Air has a reputation beyond reputeTeth-Air has a reputation beyond reputeTeth-Air has a reputation beyond reputeTeth-Air has a reputation beyond reputeTeth-Air has a reputation beyond repute
Default
I had 2 clutches snap in half while I was trying to remove. The one was the original clutch under warranty so I let the dealer deal with it and they cut into the crank trying to cut off the stub. Anyway they bought the sled and gave me a deal on a snowcheck. Moral of the story. I like letting the dealer remove the clutch for me any time my sled is in for anything else.
Try the water trick again and pour boiling water over the clutch. It helps it expand to loosen.
__________________
Home of the "Cordless Teth-Air" and NEW "Laser Phantom Teth-Air"
http://www.sourceinnovations.ca
We also have TKI Belt Drives, Arm Candy A-Arm Braces, Oil Tank Inserts, Reversible Scratchers, Polaris Suspension Couplers, Track Clips, Clutching and more.
1 out of 1 members found this post helpful. Rate this post: Yes | No
  #4
Old 01-16-2019, 02:42 PM
Solby's Avatar
Solby Solby is offline
Currently: snow, snow, snow
Solby has a reputation beyond reputeSolby has a reputation beyond reputeSolby has a reputation beyond reputeSolby has a reputation beyond reputeSolby has a reputation beyond reputeSolby has a reputation beyond reputeSolby has a reputation beyond reputeSolby has a reputation beyond reputeSolby has a reputation beyond reputeSolby has a reputation beyond reputeSolby has a reputation beyond repute
Default
Tighten the puller in tight and hit it on the end with a hammer. I don't recommend an air wrench because I used one on mine and the crank snapped through the snout 200 miles later.
__________________
2014 ProRMK 800 155
ABS Freeride Pack
  #5
Old 01-16-2019, 04:51 PM
retiredpop retiredpop is offline
Currently: Not set
retiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond repute
Default
Quote:
Thread in the puller as tight as you can. If tapping on the puller doesn't break it loose then apply some heat with a heat gun on the center shaft of the clutch beside the inner sheave. Rotate the clutch once in a while so it heats evenly. It should come off when it expands a bit. Hopefully the clutch didn't spin on the taper and weld itself. If that's the case then you probably have to cut it off.
__________________
The older I get the better I was. In fact now that I think about it I'm a legend!
Haven't outgrown my 600 yet!
  #6
Old 01-17-2019, 02:49 PM
Default
Thanks. The shop was able to rebuild it without taking it off. Not sure how but they did. Now they find that one cylinder is down to 100# compression and scored. :-( 84 hours on a "Fix Kit" and it has to be redone....again. 2417 miles on the sled and will be on it's third motor. Thinking that it's time to sell or trade and go a different direction. :-(
__________________
[SIGPIC][/SIGPIC]
  #7
Old 01-17-2019, 08:20 PM
mtncat1's Avatar
mtncat1 mtncat1 is offline
Currently: waiting for snow
mtncat1 has a reputation beyond reputemtncat1 has a reputation beyond reputemtncat1 has a reputation beyond reputemtncat1 has a reputation beyond reputemtncat1 has a reputation beyond reputemtncat1 has a reputation beyond reputemtncat1 has a reputation beyond reputemtncat1 has a reputation beyond reputemtncat1 has a reputation beyond reputemtncat1 has a reputation beyond reputemtncat1 has a reputation beyond repute
Default
your getting taken for a ride and you need a new shop. the one you are using is full of crap and can't even perform the simple task of removing a clutch, they gave up on it and told you some b/s about doing the job without doing the job ? the problem is not with the sled !
i just an old mechanics opinion take it for what it's worth
__________________
2013 163 X3 silber turbo,
  #8
Old 01-17-2019, 09:51 PM
SRXSRULE SRXSRULE is offline
Currently: Not set.
SRXSRULE has a reputation beyond reputeSRXSRULE has a reputation beyond reputeSRXSRULE has a reputation beyond reputeSRXSRULE has a reputation beyond reputeSRXSRULE has a reputation beyond reputeSRXSRULE has a reputation beyond reputeSRXSRULE has a reputation beyond reputeSRXSRULE has a reputation beyond reputeSRXSRULE has a reputation beyond reputeSRXSRULE has a reputation beyond reputeSRXSRULE has a reputation beyond repute
Default
Exactly my thoughts too!
If the dealer cant get a clutch off a sled, thats a big red flag and your invention to get your sled the hell out of there!
The Following User Says Thank You to SRXSRULE For This Useful Post:
mtncat1 (01-17-2019)
  #9
Old 01-17-2019, 10:13 PM
mtncat1's Avatar
Default
goes in for a clutch and now suddenly needs a new top end that has low miles on it even more fishy
__________________
  #10
Old 01-17-2019, 10:25 PM
94fordguy's Avatar
94fordguy 94fordguy is online now
Currently: Enjoying the snow!
94fordguy has a reputation beyond repute94fordguy has a reputation beyond repute94fordguy has a reputation beyond repute94fordguy has a reputation beyond repute94fordguy has a reputation beyond repute94fordguy has a reputation beyond repute94fordguy has a reputation beyond repute94fordguy has a reputation beyond repute94fordguy has a reputation beyond repute94fordguy has a reputation beyond repute94fordguy has a reputation beyond repute
The Following 2 Users Say Thank You to 94fordguy For This Useful Post:
mtncat1 (01-17-2019), NO IQ (01-20-2019)
  #11
Old 01-17-2019, 10:40 PM
mtncat1's Avatar
Click Here to Register
  #12
Old 01-18-2019, 09:29 AM
Teth-Air's Avatar
The Following User Says Thank You to Teth-Air For This Useful Post:
diamonddave (01-19-2019)
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — Stuck Primary Causes? Thread Starter — Skidoou Forum — Clutching Replies — 2 Last Post — 01-11-2016 06:36 PM
Thread — Primary Stuck Thread Starter — UP_CARP Forum — Polaris: Pro-Ride Replies — 15 Last Post — 01-03-2015 05:56 PM
Thread — primary stuck on Thread Starter — poledge800 Forum — Polaris: Pro-Ride Replies — 22 Last Post — 11-06-2011 06:44 PM
Thread — Primary stuck out Thread Starter — wowgogs Forum — Ski-Doo: XP Sleds Replies — 6 Last Post — 12-23-2010 08:12 PM
Thread — Help! stuck primary Thread Starter — powdercrav Forum — Arctic Cat: M Series Replies — 3 Last Post — 11-21-2010 08:50 AM
no new posts
