Upgrade to Premium
Arctic Cat: 1M 2001-2005, all models in the Mountain Cat / 1M chassis
Reply
  #1
Old 12-31-2018, 04:28 PM
DAVIS89 DAVIS89 is offline
Currently: Not set.
Basic Member
DAVIS89 is an unknown quantity at this point
Default Anyone still talkin about 1M 900 mountain cats 2003/2004?
Have a 2003 mountain cat 900 mod (carb) and gonna swap a 2004 900 EFI motor into. My 03 motor has jaws pipes, torque line RKT head and v force reeds I'm also gonna swap over. Am I gonna run into any issues? Do I need a bookdocker or some sort of fuel programmer
Rate this post: Yes | No
  #2
Old 12-31-2018, 06:17 PM
Idcatman3's Avatar
Idcatman3 Idcatman3 is online now
Currently: Not set.
MODERATOR: Premium Member
Idcatman3 has a reputation beyond reputeIdcatman3 has a reputation beyond reputeIdcatman3 has a reputation beyond reputeIdcatman3 has a reputation beyond reputeIdcatman3 has a reputation beyond reputeIdcatman3 has a reputation beyond reputeIdcatman3 has a reputation beyond reputeIdcatman3 has a reputation beyond reputeIdcatman3 has a reputation beyond reputeIdcatman3 has a reputation beyond reputeIdcatman3 has a reputation beyond repute
Garage
Default
Yes, you will need a fuel controller.
Sent from my VS987 using Tapatalk
__________________
Arctic Cat 1M and PS Moderator
'04 1M 1500 162" Challenger Extreme, M8 rear suspension, Custom jetting, clutching and gearing
  #3
Old 01-01-2019, 11:01 AM
triedit triedit is offline
Currently: Not set.
triedit has a reputation beyond reputetriedit has a reputation beyond reputetriedit has a reputation beyond reputetriedit has a reputation beyond reputetriedit has a reputation beyond reputetriedit has a reputation beyond reputetriedit has a reputation beyond reputetriedit has a reputation beyond reputetriedit has a reputation beyond reputetriedit has a reputation beyond reputetriedit has a reputation beyond repute
Default
love this sled just retired mine,IMO dont bother switching to efi unless you are going to leave it stock,unless you have A LOT of tuning expertise. the fuelly with mods definetly needs a fuel controller, and are not easy to set up and AGAIN IMO ,DO NOT RUN consistently. carb motor works way better
  #4
Old 01-01-2019, 11:45 AM
Readymedic's Avatar
Readymedic Readymedic is offline
Currently: 2019 is awesome!!
Readymedic has a reputation beyond reputeReadymedic has a reputation beyond reputeReadymedic has a reputation beyond reputeReadymedic has a reputation beyond reputeReadymedic has a reputation beyond reputeReadymedic has a reputation beyond reputeReadymedic has a reputation beyond reputeReadymedic has a reputation beyond reputeReadymedic has a reputation beyond reputeReadymedic has a reputation beyond reputeReadymedic has a reputation beyond repute
Default
I second that.....stay with the carb. Easy tuning, jets and go!!
  #5
Old 03-29-2019, 09:43 AM
Wildman9 Wildman9 is offline
Currently: Not set.
Wildman9 is an unknown quantity at this point
Default
I just picked up an 05 1M, I am taking the efi out and putting my 1035 on carbs in it, I think I will attempt to build a quiet silencer for it and dump it out in the suspension opening of the belly pan, the jaws pipes and that noisy silencer are a bit much for my old ears.
I do have a question if anyone is reading theses posts, I weigh 215 and I don't move the rear suspension a lick, I grabbed the back bumper of the sled when it was in my truck and pulled it down, I moved the suspension of the truck more then the sled. These titanium torsion springs are huge.....looks like a ton of overkill to me unless its a 400+ # rider. Is that normal on these things?
For what it is worth, to the OP, I am taking the efi engine from the 1M and putting carbs on it and putting it in my 03 ZR9, I will keep the efi crap for my 05 ZR9 efi in case it needs parts, I have a boondocker on it. Its ok, but it really isn't the hot setup. Carbs make way more power if you really understand them.
  #6
Old 03-30-2019, 04:17 PM
1Mike900 1Mike900 is online now
Currently: Not set.
1Mike900 has a reputation beyond repute1Mike900 has a reputation beyond repute1Mike900 has a reputation beyond repute1Mike900 has a reputation beyond repute1Mike900 has a reputation beyond repute1Mike900 has a reputation beyond repute1Mike900 has a reputation beyond repute1Mike900 has a reputation beyond repute1Mike900 has a reputation beyond repute1Mike900 has a reputation beyond repute1Mike900 has a reputation beyond repute
Default
Wildman, just moved my front spring mounts down since I incorporated them into the front A arm mount. Then also re-machined the triangle block 1/8" deeper all 3 places. I also made a offcenter bushing for the front mount to rotate up/down for extra tuning. I have the titanium springs, and are way stiffer than the original steel springs. But the majority of the problem is the track overtightens when being pushed down do to the front A arm mount is too low on the rails. I can press down to about half of the travel with the mods. But it is time for a newer suspension upgrade! Still a fun sled to ride with a little power! Mike
1 out of 1 members found this post helpful. Rate this post: Yes | No
The Following User Says Thank You to 1Mike900 For This Useful Post:
Wildman9 (03-31-2019)
  #7
Old 03-31-2019, 01:31 PM
Currently: Not set.
Default
that's what I was looking at doing, moving the front spring mount. I think I may take these ti springs out, seems to be overkill for my weight and any extra fuel or cargo that I would put on the back.
  #8
Old 03-31-2019, 08:34 PM
Currently: Not set.
Default
Just make sure they did not modify like I did! Replace coil area with larger sized plastic ID liner that fits spring ID too close? Has the sled been ridden lately, or not for yrs. and suspension bushings frozen to shaft? Mike
  #9
Old 04-01-2019, 05:48 PM
Currently: Not set.
Default
I haven't gotten into it yet, I just noticed there was little to no movement and looked quickly and saw a fair amount of grease on the shafts and noticed the size of the springs. Something could be seized.....it is in extremely clean condition for the age of it. I will get the skid out this summer and sort it out. Was just curious on how stiff these titanium springs really are.
  #10
Old 04-01-2019, 05:58 PM
Idcatman3's Avatar
Currently: Not set.
Garage
Reply
Bookmarks
Tags
1m 900, arctic cat, mountain cat 900
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — 2003-900 mountain cat,2004-900 king cat Thread Starter — joemama Forum — Arctic Cat (Swapmeet) Replies — 2 Last Post — 11-24-2012 11:37 AM
Thread — 2-2003 arctic at mtn cats f/s 600/900 Thread Starter — stickk Forum — Arctic Cat (Swapmeet) Replies — 4 Last Post — 01-22-2010 08:24 AM
Thread — 2003 and 2004 Mountain Cat 900's Thread Starter — smkyber Forum — Arctic Cat (Swapmeet) Replies — 18 Last Post — 03-22-2009 11:44 AM
Thread — 2004 mountain cat 900 hood vs. 2003 600 Thread Starter — gilby12 Forum — Arctic Cat: 1M Replies — 5 Last Post — 10-19-2008 05:46 PM
no new posts
