I just bought two Snoscoots for my boys. I have been through them and both are more or less the exact same. One is a 88 and the other a 89. The 89 flat out rips. The 88 seems to start out strong but then it seems like the power all of a sudden flattens out not like the 89 which pulls to top end. I checked the carbs to see if the mains were different but both carbs are identical and set the exact same.
The 88 has a B8HS plug and the 89 has a BR8HS plug which i don't think should make a difference.
I noticed the 88 had a intake leak around the read cage where a little oil/gas was slowly seaping out. I fixed that but it did not make a difference. I did a compression test on both. The 89 was 120 hot and 125 cold. The 88 was 90 hot and 112 cold. I cannot seem to find a compression spec anywhere.
If i lift the back end and WOT it seems to stay strong all the way through and it seems to get past this flat spot.
Any other ideas ? Thoughts ?
