I have a pc 800 was thinking of trading for 1100t what do you guys think of the 1100t compared to pc 800
turbo keeps hp on the two stroke. I have ridden both and the power feels very different. Two stroke power is up high in the rev's and the 4 pulls all the way from the bottom to the top.
quick question here............... i`m no turbo expert but was curious if you put a turbo on a PC800 does it still lose HP when climbing in elevation and does the torque on a 2 stroke react different then a 4 stroke ??
so being able to ride a 2 stroke turbo and owning a 1100 turbo you have felt and experianced the power delivery of both and considering the weight difference which would you say is the best all around sled?????
9lives, Madmax said it perfectly. I am 255LBS and ride as much in the trees than I do climbing. No one sled does everything but for me coming off an modded M1000 (everthing but a turbo) this sled is night and day better in all areas. To get the same power out of the PC8 add 50lbs for the turbo set up and then the extra fuel. Listen I dont want to start a back and forth on 2 stroke vs. 4 stroke but the addes weight to a two stroke and the easy 25 pounds you take off the 1100 you not far off from one another. We ride from 6-9k' feet and though I only have two rides on it, I will never go back to non turbo or a two stroke. Thats how happy I am with this sled. Good luck.
