P
Having an issue on m7. Sled was running good holding rpm on climbs etc and now have problem. Sled will run ok but cuts out once in a while, does this intermittently and sometimes will keep running other times will die, sometimes it will start back up and other times have to pull it over a few times with throttle wide open like it is flooded. Check engine light will flash but it is hard to count code (think it is 1 flash which is tps sensor) because it only does it once in a while. While trying to pull a hill sled will start out strong and then lose power and rpm like the fuel mapping is giving it more and more fuel. Did not change anything. Have heard that it could be throttle cable may be out of adjustment now, can this give a check engine code though? Thanks for any advise.
