D
I have a 2008 M1000 with a broken bulkhead and bent tunnel, I found a good used bulkhead and tunnel from a 2007 M7. Will this unit work with my M1000?
Thanks
Thanks
The m1000 engine uses a different motor mount configuration. the clutch side removable chassis plate is different, the 1000 has 5 bolts going into the motor (around the crank), the 700 only uses 4. then on the exhaust side the 1000 has a custom motor mount that is welded onto the chassis near the steering hoop, the 700 does not. the 1000 also has an extra mount on the front of the motor that the 700 again does not.
I'm not sure if the dimensions of the chassis are the same, i think they are, maybe you can swap the clutch side plate for the one off your 1000, and maybe even the front motor mount, but to get the extra exhaust side mount you would probably have to have someone weld one on.
I hope this is helpful, and maybe someone else can chime in and correct me if I'm wrong, it happens sometimes!
yep i read the first post and figured something was wrong..arctic2009 was a step ahead of me..
