-18 cooler vs 16-17 mc cooler
Jooohan87
Aug 28, 2011
36
Hello
Anyone know if the -18 mc with the new dsi engine is going hotter, cooler or the same temp as then previous 16-17 with the suzuki engine?
Heard some rumors that -18 will go hotter...
Toyotajoe
42
6
NL, Canada
Also curious to hear this.
A friend test rode last spring and swears the '18 was flashing the light in conditions that wouldn't have bothered his '16.
kiliki
13,215
2,405
Nampa, Idaho
the program is set to flash around 145 and the older gauge didn't flash until 170. they each run about the same temp just the threshold is lower.
summ8rmk
Most handsome
12,368
6,039
yakima, wa.
The 18 ER 162 seemed as good or better than my 14 153. Both 3in powerclaw.
Mountain Cat
dboivin
436
169
Michigan
rode last ride here (mi) in march and light was flashing non-stop. warm day and hard snow...boondockin slow. only ride i got on it last season. hope it does better in better conditions. :)
summ8rmk
Most handsome
12,368
6,039
yakima, wa.
2 rides on my 18 162.
Don't need the scratchers on the trail.
Highest temp i seen was 141° averages 124°. Just drag a foot every so often to keep the hifax lubed and keep temps around 113°. Skis were hitting gravel, thats why i did not want the scratchers down, don't like throwing gravel in my skid.
On my 2014, i always have to run the scratchers on the trail to keep the temps down in the 130's
Off trail my 18 runs 98-107°.
My 14 is 120's- 130's
Mountain Cat
sno*jet
2,829
1,301
now tighten that track to spec and cut your flap off buddy! lol, i might put my stock flap back on someday.
summ8rmk
Most handsome
12,368
6,039
yakima, wa.
Want a couple hundred miles of data before i trim flap for a solid baseline. Then compare to shortened flap. I believe the shorter flap will net similar results.
Mountain Cat
CRJPilot
162
98
Farmington, MN
Mountain Cat
Is there a way to display the actual temperature on the new ctec 800? All I have seen is a scale bar, no actual denominations anywhere that I can find, maybe I'm missing something?
Sent from my SM-G930V using Tapatalk
Woody67
1,439
681
Bellingham, WA
Hold lower left button down while temp is displayed and numerical value will be added to the bar.
fudge313
528
88
Finland
Thats funny when temps are 66-70c and temp light is flashing engine rpms are idleing between 1700-2300rpm.. Its trying to coolit whit gasoline..
