what is everyone doing to the 2018 850 clutch covers? removing foam from inside, cutting bottom off ?
I asked the same thing over on Doo Talk. Never got a response. I am going to be running a blow hole by the end of the week so I wasn't sure if the bottom section is needed. With all the grenading belts last year I wonder if it would protect the sled at all.
It blows air out. It blows pretty hard. You need to roll the sled over with it off to get snow packed in there. It's happened to me but the snow melts so fast and has never gotten in the belt it's a non issue. When you feel how warm the air is coming out of that hole you realize how hot it gets in there.
Remove all the foam from inside clutch area and door, remove clutch cover and take out felt and foam and you will notice a small foam piece on the bottom backside of the cover that faces the left foot well, 1 inch by 2-3 inches, cut around that foam piece and remove that bit it allows for better Evan of the hot air, keep the rest intact it helps evacuate the heat, run sled before spending ur money first,
