A
Rode yesterday for first ride. 03 Rx-1, stage one tubo, blew off the airbox repeatedly even after reclamping and zip-tieing the box to the carbs. Anyone else had a fix for this? Thanks
It is a Bender stage one kit without an innercooler so he is correct in saying it is an air box, however it would be the same problem as an innercooler blowing off.
It happens when you are under full boost and let off the throttle quickly.
The space is pretty tight and on the carb side the surface is smooth so it is hard to get the rubber to really bite and hold. The clamps are not real big but they are about as wide as will fit in the space.
We were wondering aout some additional way to hold the air box on, maybe weld some small loops and zip tie the box to the carborator heater tube that runs between each carb.
Great info! Getting the new silicon hoses today. Also ordered a BOV to add in. Hopefully all of that will take care of the problem.
Thanks again!
