has anyone notice the ridiculous amount of blowby on those pistons?
i'm wondering how the break-in procedure went and what type of oil was used?
If I remember right...... you can run stock weight or some people ad two grams.
Probably should check with Kelsey though....lol
I got the orange 13.5:1
I ride from about 3k 8k
Kelsey said that is his 3500+ head
and no .... it didn't even think about a compression test DAMN:face-icon-small-sad should have done that. sorry guys
How did your pistons look ?? did you do a compression test ?? how many miles ??
my pistons at 2800 km.
Don't sweat the compression test. Im my experience, they aren't showing the true colors (answers) on these motors. I notice (and noticed yours as well) that for whatever reason the ring wear is becoming significant in the CFI-2's and compression tests are not confirming this. For whatever it's worth.
Anybody notice the very bottom edge of the piston skirts?
Thinking of doing this to my 13. Anyone else got one ordered...i very hesitant to pull the trigger beings its a brand new sled. I'm coming off a 06 M7, stock motor, mod pipe, can all chasis/ suspension upgrades, and pc 2.25 track. i dont wanna be let down, and i have to beat my buddy's 09 m8 162 with port and polish, fuel controler by Jeff at Dakota Performance. Need ideas,wifes says shes leaving if i get a turbo....
--The blow-by may be due to loose clearance pistons/rings and RK-Tech
also explains this
This is why I ride my Pro stock. It has 4, count them 4, years of warranty. For the very small gains in performance pistons, heads or pipes give it is just not worth losing the warranty. Don't turn up the oil pump, don't add oil to the gas just ride the crap out of it and let Polaris worry about the reliability.
replaced them with RKT drop in kit.have 850 km on it now with NO issues:face-icon-small-hap.the clearance was WAY to much.0.20 mm measured 10mm from bottom of skirts,the piston crowns had INSANE clearance.Poo made sure that their pistons should never squeek.
