P
Was out for a ride yesterday and having a great day until I noticed this. The upper eyelet on the front shock was not installed on the shaft with loc-tite and the shaft had worked its way loose. The shock is likely shot. At least the cap and shaft are. Spring is salvageable. Fortunately, the shock and spring were resting on the axle for the front idlers. If that weren't true, the shaft would've stabbed the track and really effed things up.
So, periodically inspect your shock shaft at the top. If you see threads, pull it and add some loc-tite.
BTW, that's my boot lace holding the shock and spring up out of the track.
