W
Not sure what the problem is. It ran fine all last year and the only changes i made to it was a boss seat, water temp guage, Snow eliminators. Prettys sure i blead the coolent good and i have 200 miles on it this year. Any Tricks? I ordered a crossfire cooler for it see if that helps. It would over heat about every couple miles. I could clear teh cooler and it would cool down then over heat again. Tried adding feul and it helped a little but still over heated. Droped my egt's 200 degrees but check engine light. Any Ideas or shoudl i just drain the coolent and bleed again. Also once i was in the deep snow it would run 120 all day but the trail i was seeing up to 175. Also the trails were not hard pack and i run scratchers.
Performance Mods=
Speedwerx pipe and can
3 deg timing key
v-force reeds
Boondocker controler
Performance Mods=
3 deg timing key
v-force reeds
