So I am trying to decide which cold air intake to buy for my 2009 m8 with slp pipe kit. I would like to hear some opinions and some suggestions please. Thanks everyone!
I think any intake other than the slp intake requires the use of a fuel controller with the slp pipe set up. So be sure to figure the price of a fuel controller in with your price of intake.
Please explain?
I've heard from a bunch of people running a few different setups & aside from one guy on here I've never heard anyone say that.
I put the slp pipe on last year and was really impressed with the performace on my 07 M8, this year I added the v-force reeds and slp air kit and again found my self saying WOW, I to thought it was just a way to get you to buy thier stuff, but I'm convinced and have installed it on two other friends sleds after they tried to keep up with mine, only mods done and would recommend the setup.
Just add the SLP intake. It's easy to do and retains the stock air plenum so your sled won't be chocked for air in the deep, deep stuff. I have one on my 09 with the SLP pipe and I am happy. Also, they are cheap. check E bay.
So Frostbite I can get an SLP intake for cheap and it takes all the weight out of the hood?
Yes they are cheap, but no, you will not loose any weight. The SLP kit they are talking about is an add on to the stock intake system. Check it out here...
http://www.slp.cc/catalog.cfm?pageID=detail&catalogID=2&catID=6&productID=980
What all mods do you currently have and at what elevation do you ride? Are you running any guages to monitor EGT and/or AFR? Checking plugs and wash? These all factor in. All sleds are different and if yours is already on the edge and you do put an intake of some sort on, without knowing whats actually going on inside, it will more than likely end up with you parting with some cash at the parts counter..
Boone
The first year i bought my M8 i ran a full Speedwerx Pipe with a Snopro intake without a fuel controller at high elevation. snopro intake is much cheaper than the others and if you have good relations with your dealer they can get it for you even cheaper.
