Thats true, but i can turn that 20 into days so that i'm not "bothering" the wife. :face-icon-small-winsummer project that takes about 20 mins to install hahaha
Brian,
Installed mine today and like to say great job on the product. Very easy to install and great workman ship. Hope to get out and try it as stock chains haven't been standing up with a 174x2.5x16 and 860. Only getting about 200 miles before chain is stretched and ready to give problems. Keep chain tight and with hard pulls the chain keep stretching . Was going to go with 15 wide until you fellas built this. Hope that it stands up. Will giver a test. (20/49 Gearing with the chain)2.45
R.C.
Thanks again
Looks great... Quality work.
The test will come, just like the other gates equipped belt drive, in how do the belts hold up when jumping and landing on the throttle?
Any plans for other sled mfgs/models?
has anybody tried the belt drive on there turbo 1200 doos?
i was wondering if you are offering any spring check deals if someone would like to do your carbon fiber chasie with intergrated fuel tank and bulkhead:face-icon-small-hap
i could be able to drop off in may and pick up in october finished and ready to ride
you can pm me if you wish, wait for your pricing...lol
does it use the stock chain case or is it a custom bracket on the back. if so can u have them built in extended lengths
Yes you were close, but its not 3 gears because the middle one is our idler/belt tension system.
The kit includes the following:
Top Sprocket
Bottom Sprocket
Idler/tension wheel assembly
Carbon Fiber half cover
Gates carbon fiber belt
All mounting brackets and necessary hardware
A complete installation video can be found here: http://www.c3powersports.com/content/syncrodrive-installation-ski-doo-xp
here is a closer look at the idler/belt tension system. It was engineered so it can work the same as the stock chain tensioner.
