G
I have a 900 switchback that was put into storage for the last 18 months. I noticed clean oil under it on the floor, so went to investigate and found the following....
Oil was coming out from throttle body, so I pulled them off and removed the reed cages (that were also full of clean injection oil). I could then see into the crankcase. One had some oil in the bottom of it (I estimate an inch or so), when I took off the other (PTO side), it was filled to the top with clean oil.
Incidentally, I noticed the injector oil resovoir was empty, and it had been topped off prior to storage.
The only thing I noticed out of ordinary was the oil cable looked broken, like it had been stretched out. The oil valve appeared to be stuck wide open.
Can anyone help me out on this one? If the valve was wide open would it cause this condition?
Thanks in advance
Thanks in advance
