A
Couple questions/observations.
Using a 0648-774 Cat secondary spring.
Free lenght is 5.538"
Compressed is 1.461"
Secondary clutch spring clearnance is 1.521" this is with a shift assist and both of the .153" thick shims installed.
So I don't believe even at full shift this spring would coil bind. Would you agree?
Now the interesting question. When taking the secondary to full shift without a spring, it appears to me that the belt could fall all the way down to the straight cut in the secondary sheeves and even hit the helix if it wanted to. I didn't see any scuffs on the helix, I would assume it would slip like crazy if it ever shifted out that far.
Also I believe the instructions for a shift assist says to remove ONE of the two factory plastic shims (.153") when you put the shift assist in. Correct?
Anyway, tell me your ideas. I have had pretty good belt lift over all. But on a trail if I am messing around and doing some drag racing about 4-5 good pulls and BAM! their goes a belt.
Thinking the extra .153" shim was installed along with the shift assist was causing coil bind. not to sure now.
Thunder
Thunder
