EDIT 1/3/13... SAFETY NOTE from MH:
The fuel in the CFI-2 system is under pressure. If you are not familiar with fuel injection plumbing systems, the proper hose and clamps to use... do not undertake modifying your fuel system. If a hose leaks or detaches you will have fuel spraying under your hood at pressure creating a potentially explosive situation. Put it simply.. if you do not have the necessary experience with the system... find someone that does or use only factory parts. The system is simple... but there is no room for error with gasoline.
Phil seems to have that necessary experience which shows in his choice of materials.
Heres our solution to the stock filter.
This solves two problems.
1 its cheaper.
2 the stock filter never lasts very long when running race or avgas.
It breaks down the filter inside and plugs up.
So with an order into JEGS for about $60. You get a better filter and bigger fuel lines. I replaced all my fuel lines with 3/8 instead of 5/16.
Also we moved the filter up on the frame more so its easily accessible for future service. This particular filter has a replaceable or washable screen instead of buying a whole filter.
Heres the Parts list and pictures:
JEGS Fuel Filter designed for Racefuel/avgas with Stainless Steel Screen filter
3/8 Hi Pressure Fuel Injection Line
3/8 Fuel Injection line Hose Clamps.
Enjoy
