F
Otherwise it runs pretty good. Pretty good throttle response when I blip the throttle from idle, and when I sputter through the midrange the top end runs pretty good too, but it's probably not perfect. Also, after it idles for about 1 min(sounds great) the rpms fall way low, to the point of not running or hanging on by a tread. The fuel pump had a massive air leak(sucking air) but now fixed. The air box has 2 large holes cut in it from the previous owner. Could it be getting too much air? If it had flat slide carbs I'd probably move the needle position to a leaner setting. I'm not familiar with butterfly carbs.
I added a little oil to the new gas(40:1) because I was going to monitor the oil consumption for the first tank to make sure it was working. It doesn't seem to be overly smoking. This coupled with the oil injection is making me wonder if it's just too rich
