Upgrade to Premium
Arctic Cat: M Series 2005-2011, all models in the M-series chassis
Reply
  #1
Old 12-31-2013, 12:06 PM
theUltamateTBM theUltamateTBM is offline
Currently: Waiting for the weekend
theUltamateTBM has a reputation beyond reputetheUltamateTBM has a reputation beyond reputetheUltamateTBM has a reputation beyond reputetheUltamateTBM has a reputation beyond reputetheUltamateTBM has a reputation beyond reputetheUltamateTBM has a reputation beyond reputetheUltamateTBM has a reputation beyond reputetheUltamateTBM has a reputation beyond reputetheUltamateTBM has a reputation beyond reputetheUltamateTBM has a reputation beyond reputetheUltamateTBM has a reputation beyond repute
Default 07 m8 upgrades
hey all I am looking for the best upgrades for an 07 m8 the sled is bone stock right now I already am going to do the wrp boards and was thinking about a y pipe and can I don't want a fuel controller the sled is a 153 also what should I do as for as clutching thanks
Rate this post: Yes | No
  #2
Old 12-31-2013, 07:29 PM
Default
after a bunch of reading I think I might just do boards and a good clutching setup for now but as for as a good clutch setup should I go torsional or should I go with one of speedworks kits I have a torsional on my m7t but havnt run it much yet but it seems good
  #3
Old 12-31-2013, 07:35 PM
m8magicandmystery's Avatar
m8magicandmystery m8magicandmystery is offline
Currently: [Too Long]
m8magicandmystery has a reputation beyond reputem8magicandmystery has a reputation beyond reputem8magicandmystery has a reputation beyond reputem8magicandmystery has a reputation beyond reputem8magicandmystery has a reputation beyond reputem8magicandmystery has a reputation beyond reputem8magicandmystery has a reputation beyond reputem8magicandmystery has a reputation beyond reputem8magicandmystery has a reputation beyond reputem8magicandmystery has a reputation beyond reputem8magicandmystery has a reputation beyond repute
Default
thunder products 911 cover for the primary with glide washers..
stm valves to eliminate power valve motor and cables
bdx oil delete
peak reverse lever to eliminate reverse motor
backshift bearing for secondary
bdx light recoil hub and bolts
bdx light rotor and pads..
xxxrods post brace
VENTING VENTING VENTING..
__________________
07/m8 141 900 bigbore, Stm valves, Bdx oil delete, adj fuel reg, bumper kit ,Rock rollers, light hub and rotor and post brace, Fastlane no snows and 9 inch 2 wheel kit ,Dayton weights, Shift assist, Timbersled intake, Mtn tamer and Barkbuster with fox evols , Diamond s hood, Boss shorty seat ,Rox risers, Koso egts , a/r , water temp guage .Mod ski's. 911 cover
400 pounds...!!!!!!!
The Following User Says Thank You to m8magicandmystery For This Useful Post:
theUltamateTBM (12-31-2013)
  #4
Old 12-31-2013, 08:54 PM
Frostbite's Avatar
Frostbite Frostbite is offline
Currently: Dreaming of riding in deep, deep powder!
Frostbite has a reputation beyond reputeFrostbite has a reputation beyond reputeFrostbite has a reputation beyond reputeFrostbite has a reputation beyond reputeFrostbite has a reputation beyond reputeFrostbite has a reputation beyond reputeFrostbite has a reputation beyond reputeFrostbite has a reputation beyond reputeFrostbite has a reputation beyond reputeFrostbite has a reputation beyond reputeFrostbite has a reputation beyond repute
Default
I guess I am just different but I would say...........in no particular order of preference.
1. 2.6" Powerclaw
2. SLP Powder Pro skis
3. MDS clutch weights
4. 2010 seat
5. plastic board inserts of some sort
6. Arctic Cat complete coverage skid plate
I'll stop for now.
__________________
The Original Frostbite
  #5
Old 01-01-2014, 12:46 AM
butters77 butters77 is offline
Currently: dreaming of snow....
butters77 has a reputation beyond reputebutters77 has a reputation beyond reputebutters77 has a reputation beyond reputebutters77 has a reputation beyond reputebutters77 has a reputation beyond reputebutters77 has a reputation beyond reputebutters77 has a reputation beyond reputebutters77 has a reputation beyond reputebutters77 has a reputation beyond reputebutters77 has a reputation beyond reputebutters77 has a reputation beyond repute
Default
Swapping out the challenger for the 2.6 claw is THE best mod I have done to my 07... but I also 162'd my 153..
Board upgrade of sorts
Oil delete
Tunnel update
Pipe kit
Forgot of course a seat upgrade
Sent from my DROID RAZR using Tapatalk
  #6
Old 01-12-2014, 08:49 PM
mustard73 mustard73 is offline
Currently: Not set.
Basic Member
mustard73 has a reputation beyond reputemustard73 has a reputation beyond reputemustard73 has a reputation beyond reputemustard73 has a reputation beyond reputemustard73 has a reputation beyond reputemustard73 has a reputation beyond reputemustard73 has a reputation beyond reputemustard73 has a reputation beyond reputemustard73 has a reputation beyond reputemustard73 has a reputation beyond reputemustard73 has a reputation beyond repute
Default
A speedwerx y-pipe, BDX Black Boxx intake and a can doesn't require a fuel controller. These mods wake up the sled and shed some pounds. I ran this setup on my 07 for 3 years with no problems.
A track upgrade makes a big difference as already mentioned.
  #7
Old 01-12-2014, 09:06 PM
Default
that's kinda what I was thinking but I wanna do a little bit of clutching as well I plan on putting the 2.25 powerclaw off of my sled on it because I am going bigger for my turbo
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — 07 XRS 151 - many upgrades Thread Starter — frog Forum — Ski-Doo (Swapmeet) Replies — 0 Last Post — 03-23-2010 05:28 PM
Thread — 07 M8 With 09 Upgrades For Sale. Thread Starter — nickracer9 Forum — Arctic Cat (Swapmeet) Replies — 4 Last Post — 11-30-2009 10:46 PM
Thread — horsepower upgrades for 07 phazer fx? Thread Starter — Hambone24 Forum — Phazers! Replies — 3 Last Post — 02-08-2009 02:59 PM
no new posts
