I have a 2008 Dragon 700 163, picked it up used last year. Has slp pipe, can, ves hoses blocked off, etc. Now the dumb question... how "smooth" should my sled be just off idle as belt is just engaging? What I mean is when slowly trail riding as in 5-10 mph it seems like it is hunting for an rpm range (talking just enough change that I notice the motor is not smooth). It doesn't cause the sled to behave any differently or anything just more of it sounds like an old snowblower that isn't running right where you get the wer, wer, wer noise. Is that normal and possibly caused by belt not fully being engaged so it slips which frees up the motor and then catches or something? Notice similar things when tractoring through trees, but ONLY at low speed.
I've checked the TPS with analog volt meter and it's smooth... is this behavior normal or do I have a possible issue? Sorry complete newb and heading to Tog next week so if something is up want to address now in case needs to visit shop, etc. Freaking out after reading "surging" issues on other posts being the Voltage Regulator, TPS, ECM, etc.
