1100 turbo will not start
1
1709
201
178
need some help. my buddies 1100 turbo will not start, the sled has about 10 miles on it. it turns over fine but will not start. we checked for spark. yes there is spark.plugs look dry so we put some gas down the spark plug. still will not fire. no the kill switch is not on. need help on where to look next.
Snupe3
New member
Jul 7, 2012
36
4
8
36
Try taking the gas cap off and listen for air blowing out around it. Might be a vent line
1
1709
201
178
yes we tried starting fluid still did not fire. looked at all the connectors looked good. i think the hood is good because there is power to the lights. and the engine turns over.
K
kramer boy
42
6
8
Fairview Alberta
If your sure there is spark that rules out tether,or other electrical faults. Does the fuel pump come on with key for a bit? Could be pump if plugs dry. Hard to get gas into these plug holes too. Check air intake/filter to make sure a critter hasnt setup camp. Some of these sleds have poor sealing intake frogskinz and mice love these areas.
1
1709
201
178
fuel pump runs fine. put fuel down spark plug hole still will not fire.
1
1709
201
178
yes we did swap ecu off another sled. still no go. will be taking it back to dealer.
1
1709
201
178
thankyou psychosledder73 i have not tried that. i will change them and hopefully it works. has this happened to you?
