AC part went TU again, switching to the Moose. I have foamed the bars and am going to put the elements on tonight. Need to know what color is high/low on the stock set-up. Thanks in advance!
I just did mine like a month ago but I dont remember what color is what. It is pretty easy to test if you have a continuity tester. Or before you take the stockers off see what wire is hooked to the BIG element (high) and what it hook to the little element(low) then there is a common.
What is the trick? I have been without warmers since the stock elements broke for the second time 3 years ago. I would like to install something that works. Thanks
I had a green with white stripe that was low and black stripe that was high. The reversed pin was ground. Fired it up last night and they heated right up.
