Guys wondering if any of you took a look at where the oil drain plug is on the t1100?
I happened to have a SeaDoo RXP Supercharged, and I have to do the dipstick oil retrieval method after warming up the engine. You never got all the old oil out. Then you had to be careful to put the same amount of oil back in.
The dry sump system made it difficult to ascertain how much oil was actually in there. Overfill and your engine would slow down fairly significantly. YOu had the "thread the needle" to get the proper amount in.
Is there a bottom dump that goes through the belly pan?
