There is a 10mm bleader bolt with a copper washer on the front of the motor. As you look at the throttlebodies, it sits just left and under the far left #3 throttlebody, or at 9:00 if it were a clock. Disconnect your plug wires, and turn it over until oil starts pumping out of the bleader hole. This insures that oil is indeed circulating through the head as it should.
