L
Old Phazer engine won't run on right cylinder, it has a primer on it, if I keep priming it, it will run, (drove 15 miles to get it home pumping the primer). It seems like the venturi effect is not there for the right cylinder.
Float bowl full of gas.
Compression is good.
Cleaned the carbs many many times.
Reed valves look good.
Pulled the crank, seals look good.
New needle and seats.
Piston skirt looks good.
Swapped carbs.
I'M STUMPED!
Swapped carbs.
I'M STUMPED!
