Pulled my first cord on a belt today. Right at 612 mi, and I had been flogging it in over the hood powder for an hour and 42 minutes pretty much non stop. Belly fight grenade, just pulled about an inch of cord, so now it will be a spare. No complaints at all any the belt life, I was abusing it hard today. Sure is a fun sled in the deep stuff though.
By adjusting Clickers you move the eccentric effectively moving more weight ahead of the pin and adding weight -- if you go up to a higher number it does the opposite effective removing weight from ahead of the pin. So the Clicker is a way to add or reduce weight without much fuss. If you run out of adjustment on the clicker you need to add or subtract weight on the pin or go to a different weight shift arm all together. In the race manual it actually tells you how much weight each clicker adds.I'm not saying I don't believe some people are having issues. I know it is there but it isn't on every single model out there. So to be scared away from buying this machine makes no sense. It is a luck of the draw type of thing it seems, which sucks.
What I'm getting at is if people believe they are having problems because of too much rpm and then adjust their clickers to compensate are they potentially doing more damage as they don't realize clicker position doesn't affect RPM. Instead clicker position should be used as snow conditions vary. If you want to change engine speed change weight. Although, yes, RPM might slightly be affected by clicker change it isn't substantial.
I'm at roughly 21 grams per pivot turning 8000 clicker 3 at 5,000 ft.
Pulled my first cord on a belt today. Right at 612 mi, and I had been flogging it in over the hood powder for an hour and 42 minutes pretty much non stop. Belt didn't grenade, just pulled about an inch of cord, so now it will be a spare. No complaints at all with the belt life, I was abusing it hard today. Sure is a fun sled in the deep stuff though.
had same set up yesterday in super deep fresh, was still
pulling 8100 on #3. adding next size shim puts me @ 24 gr
that should be nutz for me. any issues with running 3,4 and 7mm on the 38mm bolt?
Use your clickers go down to 1 if needed it is the same as adding weight but over the whole shift curve not only in the middle--so actually better.
the fix is a paragon cluch I get near 3000 mi on a 391 belt on my xm.Have you tried a Gates Belt ?
BRP's 2018 media releases regarding improving 850 CVT heat issues (cooling fan, airflow mgmt across the CVT system etc) seem to be good additions to minimize the effect of the symptom of heat produced.
My questions for brpcare:
1)Has your engineering and production team determined the cause of the actual higher than normal CVT temperatures in the G4-850 Summit line for 2017?
2) Why do the G4-850's that are NOT problematic in terms of frequently blown belts, still have higher than normal CVT temps when compared to the ETEC 800's, and even high HP turbo versions of the ETEC 800's?
This question is related to 3 G4-850 sleds I have in my shop right now.
Cooling fins/ fan on the back of the fixed half of the primary clutch.
Just seams like this is a temporary fix for another much bigger problem.. How many sleds out there making much bigger power than 160 and sot having cooing fins on primary.. Maybe find the reason for the heat and fix that:juggle:
Daag44 I've been watching all the forums for a real fix for the hot clutch issue
And I dont believe I've come across the fix,
Just suggestions to deal with heat from the clutches.
I agree with fredw about the hot clutch issue being more about the rider and not the sled..
The guys blowing belts are blowing through a tank of fuel in 2 to 3 hours?
I burn 5-6 gal. In 6hours
And my clutches are way too hot to touch.
Still on my original belt @ 500 miles
