In Sicamous, BC this weekend my 15 pro (stock except for clutching, gear down kit and fix kit 2000 miles ago) hit DET 13 times on the PTO side and 2 times on the MAG side. Happened on the trail, in the trees and in the alpine, typically around 7000 rpm with the sled running at normal operating temp of 125. Checked all the spark plug wires and caps, they look good. Replace plugs, replaced fuel filter and am still hitting DET. Has anyone experienced this and found what was causing the issue. My thoughts are
- Loose/smooth belt causing clutch to over rev. Unlikely
- Bad fuel, however I put about 60 litres of shell premium in this weekend and still an issue so its unlikely as well
- Sticky exhaust valves or broken VES springs?
- Fuel Pump?
- Faulty DET sensor? Havent heard of these being an issue in 13-15 pros
Please let me know what you think or if I am missing anything. Thanks
- Fuel Pump?
