X
So i just got this sled (thrown in with trailer).Its a 1995 Ext 580. Heres the little background i know. The previous owner knew nothing about it. Had it for 5 years, seeing minimal use and hadnt actually started it up this season. I did a compression check and got 100 psi out of both cylinders. i changed out all the fuel, put new plugs in and cleaned it up. It will fire when choked, and once running for 45-60 seconds, will want to die (no choke). i will give it gas and it will just sputter and die. If i pull the choke when it is dieing it will pick up the idle and run idle ok. The plugs are wet after runnign for a min or two. I can pull the airbox boots and they are wet with gas as well. it has a 270 main and i dont know what the pilot is, fuel screw is 1.5 turns out. ideas on where to go now?
