R
I have a 05 rmk. I have 2013 shocks and a arms and tie rods with all the ends . Also have 2010 spindles. The spindles are on it now. Question is we ill the 2013 arms work with out modification?
Yeh they will work work no problem. As long as the shocks and tie rods are the correct length for the arms being used. If it was all off the same sled your fine.
Only issue is the shocks, they are from a 2013 sled, which is from a sled that had a lighter front end, and the 900 has a heavy front end so essentially they are not valved for the heavier weight.
