05 900 RMK died on trail. No spark
H
Feb 13, 2011
132
22
18
40
Over here
Was riding my 05 900RMK the other day. Everything fine untill out of nowere the engine started to stutter and backfire for few seconds then it died. And it dont get spark anymore.
What can this be
Cerialsledder
SnoWest Badge Maker
1,873
1,128
Sault Ste Marie, MI
Unplug your kill switch and try it, if not that then check was the wires run into the coil. Sounds to me that something finally wore through and is grounding out on ya.
H
Feb 13, 2011
132
22
18
40
Over here
I did unplug the kill switch and no change. Also checked the wires from back of the ecu to the coils and all fine. But would both coils go out at the same time ?
D
Nov 2, 2008
79
14
8
46
I'd check the stator. My guess is either the flywheel ring came off or the stator is loose.
Just an FYI, don't put he bottom bolts in the recoil cover. I actually ground the cover some and left the bolts out. Now I can take it off without loosening the motor.
D
HalfBrit
351
67
nw oregon
check ohms on stator. mine broke a wire near the top of adams. sputtered and died. fired one more time for 30secs or so. then never fired again til new stator.
H
Feb 13, 2011
132
22
18
40
Over here
Did a test and the stator is dead. Got the flywheel off and the tank off. But there is no way to get the plugs past the motor mount to replace the old stator. How is this done or am i doing this wrong ??
mtbraun
117
13
18
48
Cable
You can get the stator cable out from under the engine, in between the motor mount and the frame, just underneath the recoil cover. I just did mine with motor mounted. Takes a little work, but can be done.
