ok... got my last bid sent out! I'm headed out with a hammer & a crescent wrench to get this thing figured out! Oh, and a flathead screwdriver.
Not the 800's there taper fit the 600's are still splinde. cheers
It's the governor cup that's got the taper in it.Thats why you can remove the TRA III's it's splindes NOT tapered.The updated ''sliding half'' for a 06 clutch is the same as a the new tapered clutch.Just did one for mountainhighs son.Came with sping cup and all the pins and bolt to hold the arms in.yeah the sliding half is taper fit, so once you torque it on it won't come off like the tra IIIs... but the governor cup is only held on by the main bolt.. take off the bolt and the governor cup should slide off giving you access to your pins / rollers / weights / ramps
i've never tried this . just speculating ..
I bought the forks when I first got my Rev in 05 and tried them a couple times,haven't used them in years(PIA) once you pull the clutch apart a few times it's easier without them.pretty sure you don't need to pull the clutch if you are only adjusting weights
undo the bolt and the governor cup should just slide off.. right ? no need for special tools, can do in the field and no need to worry about indexing to the crank. just put the cup back on the same way it came off
make sure to have your forks, otherwise your sliders will fall all over the place, but it's not so bad since they aren't spring loaded you can actually put them back in by hand (if you don't have those forks)
I have an Ultimax belt for a spare(free from a friend) and I automaticaly loose 200RPM when I use it.Check all the little things....the chain and track tension...too tight on the chain or too loose or tight on the track can drop RPM.
I would caution against anything but a Doo belt....-391 or -377 only! I know some guys like them (aftermarket belts) because they are less money but I have also seen very extensive damage to chassis and engine cause directly by (IMO) some of those fancy new belts and the manner in which they fail.
You might even take your sled to the dealer and have them throw it on the BUDS to be sure it's showing full throttle opening.....I'm not privvy to all the other info shown on BUDS, but make sure everything is in spec. to be sure your not chasing your tail.
I think a lot of the guys in the cat section are just frustrated right now, so things get out of hand over there way too often... I feel for them, they must not have your brace on their sleds:face-icon-small-blu
After another season of testing we have found the best thing that fixes all the problems with the proclimb is the XM!
"Vent" He's only did one side!custom air vents.LOL
