M
here i go again. 2009 assault. just had troubles after a rebuild ended up needing another fuel injection harness. now sled is hard starting idles a little high, sounds good after that. runs really rough at low rpm with power commander hooked up and even stalls it out. i did put 50:1 gas in tank per some advice could that be just too much? now the engine code flashes 7 times, went out once then came back. the book say's 7 flashes isn't used. oh ya, still in garage, never took it out on snow yet. did find that i still don't have continuity between engine ground and chasis
