#1
Hello,
Couple quick questions...... I just purchased the 39” stance. I have seen a few posts talking about having to grind the spindles. Am I supposed to do that with my 39” or is that only for the 36” ones? Also they came with tie rods but do I need to use those since it’s supposed to be the stock stance? Thank you for the help. The install instructions are pretty weak. |
The Following User Says Thank You to Polaris900RMK For This Useful Post: | ||
skydog77777 (12-11-2017) |
#2
I know for sure you don't need to use the tie rods. Stock ones work fine. As far as the grinding with the 39" stance I don't think you need to grind them. Pretty sure grinding the spindles is only on the 36" arms...
__________________
2019 Black 163" 3" (My sled) 2018 Orange 163" 2.6 (Wife's sled) 2016 Black / Orange Axys 163" 3" (for sale $7,500) 2016 Red / White Axys 163" 2.6" (for sale $7,500) |
#3
Thanks Dude. I appreciate the reply ;-)
#4
Not sure on the Axys but on a Pro, the 39" Z-Broz you ended up with some pretty good marks in the spindles after turning each way max. A guy could have ground them a little to avoid but again, not 100% sure on the Axys but as mentioned above I know the 36" you do.
__________________
Polaris Pro RMK Axys / 163 Polaris IQR 600 HD Street Glide with all kinds of goodies Legend Enclosed Trailer (the toy box) |
#5
I installed a 39" kit on my 17 axys pro and had to grind my spindles. I put everything on and lifted the front end with a block under the belly, turned the steering both ways and marked the rub spots, then used a flap disk to gently bring those spots down. Not too much material taken out but its a bummer you have to do it in the first place.
The Following User Says Thank You to southlake For This Useful Post: | ||
FatDogX (12-12-2017) |
#6
Well that’s a good direct answer that I needed. Thank you! Hoping to have time to mess with them this week.
#7
Not sure why you have to grind a 39 inch kit...
Take a look at those kits, stock geometry and no modifications needed : www.trenchers.ca/en (price are in CAD) |
#8
![]() Quote:
#9
![]() Quote:
Heim joint instead of pressed in ball joint. No removal of old parts. Canadian Company. Prices are in Canadian Dollars.
__________________
Missing Digit Motors-- Servicing your 2011-current ProRMKs in Truckee, CA Truckee's source for BMFab,Camso Tracks, Indy Specialties, Lectron Carbs, Mountain Side Products, Mystik Oil, RAZE Motorsports, Speedcell and other fine snowmobile products Speedcell Technologies-- Founding Member |
#10
![]() Quote:
I was referring to their A-Arm kit which shows non-heim joint and states you need to re-use bushings/ball joints. Actually about $40 more than ZBros using todays rate of .78. They do include a ball joint removal tool though. |
#11
![]() Click Here to Register |
#12
#13
Bookmarks |
Previous Thread
Next Thread
Thread Tools | |
Display Modes | |
Thread | Thread Starter | Forum | Replies | Last Post |
Thread — zbros 36" installation question | Thread Starter — sledhead_79 | Forum — Polaris: Pro-Ride | Replies — 25 | Last Post — 02-18-2015 02:06 PM |
Thread — Aligning skis after zbros 36" install | Thread Starter — ur_moms_house | Forum — Polaris: Pro-Ride | Replies — 3 | Last Post — 01-09-2014 08:39 AM |
Thread — Twisted install question | Thread Starter — Proven | Forum — Arctic Cat: TURBO | Replies — 4 | Last Post — 01-17-2010 04:38 PM |
Thread — Goldfinger Install Question? | Thread Starter — Plantin_Tracks | Forum — Washington | Replies — 1 | Last Post — 01-02-2009 10:34 PM |
Thread — HPS XP can install question, and sound baffel question | Thread Starter — Sledskisteeze | Forum — Ski-Doo | Replies — 2 | Last Post — 11-16-2008 06:14 AM |
