Ran into an acquaintance that has ties to Cat reps. Cat rep was quizzing him re: what he recommended for changes to the Cats going forward. Apparently sno check numbers are pretty dismal for cat. Personally, having owned all 3 current models I prefer the cat for an all around package. What would you change if you were Cat? The following seems obvious to me:
- Skis (maybe 2% of people like the too narrow stock skis so this should be easy to fix).
- Weight - seems like a no brainer. No matter how well you move, if you're the fattest chick at the dance people will look elsewhere. Assume the Pro is 45 lighter, if cat could at least cut this in half I think the "heavy" label, which is more perception than handling, would fade away. Belt drive?
- Clutching - not sure it's fixed. I grenaded a belt at about 450 on the '14. Dangerous situation actually. Clutches still too hot, losing performance in really tough conditions. If I move on this will be the biggest reason.
- Cleaner, more efficient 800 akin to the 600? My mileage sucks re: the Pro (usually 2 gals. per ride). Doo actually sucked if you were in tough conditions but few realize that.
Frankly, most of this seems pretty fixable. If it were fixed, I'd stick around.
