Axys sidekick whistle at very minimal throttle
D
Dec 17, 2011
23
I got a problem with a whistle, not a spooling whistle, at very low rpms and really crappy performance. Studders, blubbers and only pulls 7500rpm! I just got a new BD air box and that did not fix it either. I've went over every fitting, clamp, mating surface and have come up with nothing wrong! Any help would be muchly appreciated!
aksledjunkie
902
375
Alaska
Not as familiar with the boondockers setup but if you've already checked everything for leaks sounds like you are working down the right path. Try spraying some soapy water in different suspect issues for a leaky seal?
D
Dec 17, 2011
23
So I'm assuming you have the intake that you cut the plastic intake box and it's all exposed on the front?? And I'm very intrigued to see what my wheel looks like after seeing yours!
