The 162 was a great addition if this was my main sled. However, I have my "Bomb" that I like to ride when the snow is deep, or we just wanna put some marks on the hills.
So I decided to put a 150 Camo Extreme on it and make it more of a boondocker/jumper all around fun sled. That was the extent of my plans....and then the wheels started turning.....
Simmons skis got traded for C&A Pros - Float ok, good enough for me, little sketchy when counter steering as they want to jump outta my hands when they reach a certain point. After that initial jerk, they become quite predictable. Think I may play with the outer edge and taper it back some.....see if that helps.
2Cool Vents were added - Best vents in the business! When people notice them, they constantly get props!
Stiffer Front Shock Springs and no Swaybar
Sportech Headlight Covers - Bling
Sportech Windshield - Bling
RND Risers - 8" Riser only because RND doesn't make 10"
RSI Handlebars - 2" Rise which makes the handlebars 10" high and perfect for my short and fat frame.
RSI Heaters - Not as impressed as others on SW. Hot is only slightly hotter than Low. But combined with the handguards, I only complain on the cold cold days.
Powermadd Throttle Block - Would be impressed if they had another hole so I could mash the flipper to the bars....instead I have to watch I don't stretch the cable too much.
FabCraft Mtn Bar - None better.
Removed stock handlebar cluster Mounted new switches on Dash - Bling, and function....I was always trying to perfect the knee on reverse button trick before.
Used old style RER button and mounted next to Choke - Only problem is people don't think I have reverse anymore.
150 Camo Extreme - Loved the track on my Cat, love it on the Doo.
136 Renegade Skid with SLP Extensions - Coupled rear skid for ZERO $$$$. T-Sled and KMod.....are nice but my wallet with some greenbacks is nicer!
Re-did the clutching and new gearing for shorter track
Things yet to be done are to install a 151 Live Rear Axle M-10, Cat extrusions to shorten the running board area, and a new tunnel extension similar to the VE kits that incorporate suspension mounts and tie everything together.
So far this is the way I'll run it this season, need a snowflap though!
If anyone knows where I can get a good condition Moto-Ski SnowFlap, it would be much appreciated.
Lemme know what you think!
