Upgrade to Premium
Reply
  #1
Old 10-30-2017, 11:40 AM
Turblue's Avatar
Turblue Turblue is online now
Currently: Sledding soon
Turblue has a reputation beyond reputeTurblue has a reputation beyond reputeTurblue has a reputation beyond reputeTurblue has a reputation beyond reputeTurblue has a reputation beyond reputeTurblue has a reputation beyond reputeTurblue has a reputation beyond reputeTurblue has a reputation beyond reputeTurblue has a reputation beyond reputeTurblue has a reputation beyond reputeTurblue has a reputation beyond repute
Default 174 Sidewinder build and season ride report.
Just thought Iíd start a post on my current Yamaha Sidewinder 174 build. Also probably keep the thread going through the winter on how the sled is working. Hereís a brief overview of what Iíve done this summer . Installed CR racing 174 tunnel extension, boards, and exhaust. I went with camoplast 174 9271m mostly because the deal was worth it...i figured worth a try......installed avid drivers. I kept the suspension in stock configuration for now. Iceage cut me a set of 174 rails...i am planning on going with different ski and rear skid shocks...currently working with a company in canada to get that figured. Also have wired in push button start and reconfigured the handlebar controls. More to follow....will post some details over the next few days.
Click image for larger version
4 out of 4 members found this post helpful. Rate this post: Yes | No
The Following 7 Users Say Thank You to Turblue For This Useful Post:
Boosted Brad (10-30-2017), Calvin42 (10-30-2017), christopher (04-04-2018), justinkredible56 (10-31-2017), mtncat (10-30-2017), niner (10-31-2017), Snowmixer (10-30-2017)
  #2
Old 10-30-2017, 10:01 PM
bdcat162 bdcat162 is offline
Currently: Not set.
Basic Member
bdcat162 has a brilliant futurebdcat162 has a brilliant futurebdcat162 has a brilliant futurebdcat162 has a brilliant futurebdcat162 has a brilliant futurebdcat162 has a brilliant futurebdcat162 has a brilliant futurebdcat162 has a brilliant futurebdcat162 has a brilliant futurebdcat162 has a brilliant futurebdcat162 has a brilliant future
Default
Gonna be a monster thats for sure.
The Following User Says Thank You to bdcat162 For This Useful Post:
Snowedunder (10-30-2017)
  #3
Old 10-31-2017, 05:09 AM
Turblue's Avatar
Default
Last year I only rode the sled a handful of times, including the demo ride I was on, which sucked me right back to Yamaha. The sled worked so unbelievably well out of the box I was impressed. There were a few things, like always, I need to change to make it better for me riding style.
First off, I’ve always liked the feel of a 174” track, floatation, and traction. Chad at CR does an amazing job with the parts for these sleds...I installed the 174 extension and CR extreme boards. Install went pretty well....make sure to take the time and square up things to the sled prior to putting the rivets in. The new extreme boards should work well on the deep days. That’s on thing I haven’t liked about many of the sled manufacturers....better boards are a must.
I then wanted a bumper that I can actually grab when buried in the snow. The LMS (Lethbridge Machine Shop) bumper looked like exactly what I was looking for. So I bought a used pro rmk one, cut it to a taper and welded the ends shut. Installed rivnuts to make it a clean install....it worked out pretty well.
Since I really liked how the sled handles stock , I wanted to keep it as close to stock going to 174 rails. Iceage cut a sweet set of black 174 rails. http://www.iceageperformance.com I added skidoo scratchers since I tend to wreck the non reverse kind. Lol. As for shocks I have been working with John at Accelerated Technologies in Ontario. http://www.acceltechracing.com/
Im planning on going with Elka front ski shocks and rear skid shock. Elka doesn’t make a ski shock yet to fit the mtx ...so John is working with them to make a custom angled rezzy shock.
Steering/controls was a big part of the modification I wanted to do on this sled. I really like the idea of a push button start on the bars. Also clean up the controls and have a cleaner setup. I am pretty close to how I want them now, but not completely there. First off the brake and hand warmer switch block had to go. Coming off a skidoo xm I figured it made the most sense to go that route. So I installed a 2015 summit brake and rer/dimmer cluster. Wiring it in was relatively easy. I basically series/paralleled the key switch circuit . I added a mini hella waterproof really and a programmable timer relay to kill the power to the switch after it’s started. The main relay is there basically because I don’t think the rer contacts are rated very high. I set the timer for 20 seconds..so after the key is on, kill switch on and tether installed it kills power 20secs after. Power cycle resets it. Also taking the key out will still secure the sled...if you used a higher rated start switch you would only need the timer relay...here is the circuit. Disregard the scribbles on the key switch diagram I was thinking out loud. Lol.
Now I needed to do something with the dimmer and hand warmer switches...dimmer pretty easy wiring to the rer dimmer switch. Hand/thumb warmers I wired to pro rmk switched in the console along with the tether. Worked out really well. I may try a Munster finger throttle if they start making one for the newer yammies, but not convinced yet. I am running CFR turcotte bars, skidoo adjustable riser and summit grab strap. I was running the CFR knucks risers prior but couldn’t make them work with the skidoo strap. I will mention in order to run a skidoo riser you need to grind the point of the tee post.... Not that bad though.
Motor wise I’m planning on running stock with a CR racing resonator exhaust. Possibly a cold air intake, but I have a couple things I might do intake wise. The stock Can is fairly heavy so it’s a easy weight savings. Also has easy access to the chaincase adjuster then. I powder coated my heat shields in high temp black. They don’t get that oxidized aluminum look then.
I was planning a cool wrap for the sled, but decided to just go with a Yamaha themed tunnel wrap for now from Marc at http://www.spiralusdesign.com. He did a great job on all my sled wraps...also if anyone needs a wrap for there 174 CR tunnel he will have the measurements now. We will probably have to tweak a bit after I get it, but after that should fit. I also have a few other cool things I’m working on...will post once I have them figured. All for now... any specific questions post them or pm me I more than happy to help out.
The Following 8 Users Say Thank You to Turblue For This Useful Post:
APEXXPRESS (11-01-2017), Boosted Brad (10-31-2017), christopher (04-04-2018), Diamond8 (11-28-2017), higherpower (11-05-2017), niner (10-31-2017), skidawg (11-01-2017), vernon (12-27-2017)
  #4
Old 10-31-2017, 02:52 PM
Motorbreath_ Motorbreath_ is online now
Currently: Loving my Summit 850!!
Basic Member
Motorbreath_ has a reputation beyond reputeMotorbreath_ has a reputation beyond reputeMotorbreath_ has a reputation beyond reputeMotorbreath_ has a reputation beyond reputeMotorbreath_ has a reputation beyond reputeMotorbreath_ has a reputation beyond reputeMotorbreath_ has a reputation beyond reputeMotorbreath_ has a reputation beyond reputeMotorbreath_ has a reputation beyond reputeMotorbreath_ has a reputation beyond reputeMotorbreath_ has a reputation beyond repute
Default
Nice! Im particularly interested in the push button start. I may have to try this myself. Good job!!
The Following 2 Users Say Thank You to Motorbreath_ For This Useful Post:
Snowmixer (11-01-2017), Turblue (10-31-2017)
  #5
Old 10-31-2017, 03:45 PM
IceAge Performance's Avatar
IceAge Performance IceAge Performance is offline
Currently: Turning dreams into billet parts!
IceAge Performance has a reputation beyond reputeIceAge Performance has a reputation beyond reputeIceAge Performance has a reputation beyond reputeIceAge Performance has a reputation beyond reputeIceAge Performance has a reputation beyond reputeIceAge Performance has a reputation beyond reputeIceAge Performance has a reputation beyond reputeIceAge Performance has a reputation beyond reputeIceAge Performance has a reputation beyond reputeIceAge Performance has a reputation beyond reputeIceAge Performance has a reputation beyond repute
Default
Nice looking build! That is going to be a fun rig when your all buttoned up.
The push button start is a super clean little add on.
__________________
IceAge Performance
Custom Slide Rails and Billet Accessories
877-5-ICEAGE
info@iceagemfg.com
http://iceageperformance.com
The Following 2 Users Say Thank You to IceAge Performance For This Useful Post:
ATVPT (11-01-2017), Turblue (10-31-2017)
  #6
Old 11-01-2017, 08:03 PM
Turblue's Avatar
Default
I rode a few days with the push button start last year....worked awesome....tree riding and exploring new terrain seems like a guy starts and stops lots discussing lines.
Also working on a rear rack ...going with the linq system. Kurt at http://www.canadasledparts.com/produ...nnel-adapters/
Has made some adaptors for the tunnel and currently making a platform so I can run the linq gas can and burandt tunnel bag. Really like that setup on my summit
  #7
Old 11-01-2017, 08:13 PM
BBNytro's Avatar
BBNytro BBNytro is offline
Currently: FIguring out all the buttons on new sled!
BBNytro has a reputation beyond reputeBBNytro has a reputation beyond reputeBBNytro has a reputation beyond reputeBBNytro has a reputation beyond reputeBBNytro has a reputation beyond reputeBBNytro has a reputation beyond reputeBBNytro has a reputation beyond reputeBBNytro has a reputation beyond reputeBBNytro has a reputation beyond reputeBBNytro has a reputation beyond reputeBBNytro has a reputation beyond repute
Default
I wish someone would come up with a better rear bumper design the AC one is useless. I put the CR boards on right off the bat, a real pain in the *** to install, but worth it.
  #8
Old 11-01-2017, 08:23 PM
Turblue's Avatar
Default
I agree the rear bumper and snow flap combination is terrible. That why I went this direction. At least have something to grab. I’m also Fabing up a couple ideas for a removable snow flap. Started last spring but got side tracked. I see doo has one now.
  #9
Old 11-04-2017, 07:47 AM
Turblue's Avatar
Default
Well I have to say Iím not the type to have a really flashy look...really like the clean look. This wrap that Marc at http://www.spiralusdesign.com/index.html did a spectacular job. Really like the matte finish.
3 out of 3 members found this post helpful. Rate this post: Yes | No
  #10
Old 11-04-2017, 10:13 AM
Turblue's Avatar
Default
The pro rmk connector bags sure clean up the wire connectors....part # 2687067
  #11
Old 11-04-2017, 02:45 PM
Turblue's Avatar
Click Here to Register
The Following User Says Thank You to Turblue For This Useful Post:
higherpower (11-06-2017)
  #12
Old 11-04-2017, 03:46 PM
Snowedunder's Avatar
Snowedunder Snowedunder is offline
Currently: Waiting for my 850 poo
Snowedunder has a reputation beyond reputeSnowedunder has a reputation beyond reputeSnowedunder has a reputation beyond reputeSnowedunder has a reputation beyond reputeSnowedunder has a reputation beyond reputeSnowedunder has a reputation beyond reputeSnowedunder has a reputation beyond reputeSnowedunder has a reputation beyond reputeSnowedunder has a reputation beyond reputeSnowedunder has a reputation beyond reputeSnowedunder has a reputation beyond repute
  #13
Old 11-04-2017, 04:06 PM
Basic Member
  #14
Old 11-04-2017, 05:51 PM
Turblue's Avatar
  #15
Old 11-07-2017, 09:11 AM
Calvin42's Avatar
Calvin42 Calvin42 is offline
Currently: Liv'n the Dream everyday
Calvin42 has a reputation beyond reputeCalvin42 has a reputation beyond reputeCalvin42 has a reputation beyond reputeCalvin42 has a reputation beyond reputeCalvin42 has a reputation beyond reputeCalvin42 has a reputation beyond reputeCalvin42 has a reputation beyond reputeCalvin42 has a reputation beyond reputeCalvin42 has a reputation beyond reputeCalvin42 has a reputation beyond reputeCalvin42 has a reputation beyond repute
  #16
Old 11-07-2017, 09:32 AM
Turblue's Avatar
Calvin42 (11-07-2017)
  #17
Old 11-10-2017, 08:59 PM
kakwa climber's Avatar
kakwa climber kakwa climber is online now
Currently: Waiting for snow
kakwa climber has a reputation beyond reputekakwa climber has a reputation beyond reputekakwa climber has a reputation beyond reputekakwa climber has a reputation beyond reputekakwa climber has a reputation beyond reputekakwa climber has a reputation beyond reputekakwa climber has a reputation beyond reputekakwa climber has a reputation beyond reputekakwa climber has a reputation beyond reputekakwa climber has a reputation beyond reputekakwa climber has a reputation beyond repute
  #18
Old 11-11-2017, 08:05 AM
Turblue's Avatar
The Following 2 Users Say Thank You to Turblue For This Useful Post:
BCBOOST (11-11-2017), Boosted Brad (11-21-2017)
  #19
Old 11-22-2017, 07:14 AM
Turblue's Avatar
  #20
Old 11-22-2017, 07:34 AM
Basic Member
  #21
Old 11-22-2017, 07:49 AM
Turblue's Avatar
  #22
Old 11-22-2017, 09:02 AM
Calvin42's Avatar
The Following User Says Thank You to Calvin42 For This Useful Post:
Turblue (11-22-2017)
  #23
Old 11-24-2017, 09:53 PM
Turblue's Avatar
ATVPT (11-25-2017), dropitbuster (11-25-2017)
  #24
Old 11-25-2017, 07:57 PM
Turblue's Avatar
  #25
Old 11-27-2017, 10:18 AM
Calvin42's Avatar
Turblue (11-27-2017)
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — Ride report Yamaha Sidewinder Thread Starter — Turblue Forum — General Snowmobiling Replies — 55 Last Post — 01-30-2018 08:04 PM
Thread — T3 174" Turbo build Thread Starter — Aerocharger_Calvin Forum — Ski-Doo: TURBO Replies — 0 Last Post — 11-18-2015 09:57 AM
Thread — weather report for next season Thread Starter — donbrown Forum — General Snowmobiling Replies — 11 Last Post — 04-30-2015 10:53 PM
Thread — Off Season Build Time Thread Starter — edavis0202 Forum — Polaris: Pro-Ride Replies — 8 Last Post — 07-16-2012 07:00 AM
Thread — 174 build Thread Starter — jehay Forum — Yamaha Replies — 2 Last Post — 11-05-2008 10:17 PM
no new posts
