A
Well, I just changed my ski adapter from the straight to the offset trail adapter. When bolting the ski back on, there is a lot of play between the bolt and bolt hole in the adapter, as well as play between the offset adapter and the ski plate. Is this normal? It has been a long time since I have seen it bolted together, and can't remember.
I looked at the picture in the manual, and it shows 1 bolt and nut holding the ski to the adapter, with no washers, plates, ect. Is this correct? There is a great amount of slop there, as the offset adapter is not as wide as the original with it's wider bushings. Also, when I lift the front end off the ground, the ski can be moved by hand a whole lot!!
Any help here? It just seems weird, even thought it matches the picture in the manual. I almost think the offset adapter needs a bushing, to make the hole more the size of the bolt. And, there could be washers / bushings on both sides of the offset adapter, inside the ski mount.
What do you think? Am I missing something? Is this normal?
Thanks...AkBillyBow
Thanks...AkBillyBow
