Powder Special/Extreme
4.00 star(s)
Momma
199
206
In the heart of the Kootenays BC
Does anybody still ride Powder Specials and/or Powder Extremes?
Yup, I have a 600efi Powder special for pulling my kids in the skimmer and as a back up sled. It was my primary sled last year. I love that sled. Just easy to ride, easy to start, anyone can ride it.
Cracked my window when I ended up upside down the week before when I was fooling around. Not when I was pulling the kids.
Momma
199
206
Leason learned.................................
When the speedo stops working ya better be heading for the truck ! When the driveshaft bearings go out the speedo quits working, its a good time to start limping back !
For what they were, those sleds worked rather well !
Yup!!! That happened to me last year on the Powder Special. I thought Ohhhh maybe it's just the speedo cable, even though I was told it was probably the driveshaft bearing. Hard lesson learned, but a good lesson.
I learned a heck of alot about my sled in the week it took to fix it.
CascadeXP
88
12
Maple Valley, Washington
Still got my 98 600 EFI Powder Special. Runs great, and is my extra sled for when I take friends, or the wife. I usually trade off at some time during a trip and It's really a blast to ride. It won't go through the deep like the new sleds but otherwise you can sidehill, flip it around through the trees, and just have a blast. There was a reason it was the sled of the year in 98. :beer;:):beer;
sdsnocop
1,441
2,192
Hot Springs, SD
Still riding my Powder Special. Had it for 5 years bought it cheap with burned down motor. Runs great, boondocks very well after modifications.
97 580 carbed
Wisco pistons
AC roller secondary
UFO's on carbs
141 1.75 track
4" riser with mountain bar
Home built fuel can rack
Sport Tech windshield
Engine Pro 5x
676
115
KANSAS
Hey thanks P-S-500! We try to take good care of our sleds. Here we are pushing our way through Heavenly Valley at Grand Lake !! >>>>.
wildcard28
1,477
202
Clarkston WA
s375.photobucket.com
I still have my Arctic Cat 580 Powder Special, still fun sled, Wife rides it now.
All stock other than I put 8th drivers to install a 136 x 1 3/4 Challenger Track, and mover steering post forward about 2 inchs and a 4 1/2 bar riser, alot more fun sled.
Would like to put bigger motor, or a triple in it. but fine the way it is now.
Only pic I could find now, maybe try more later.
G
geberhard
160
Oxford, Mi.
www.theeberhards.com
97 580 carbed
Wisco pistons
AC roller secondary
UFO's on carbs
141 1.75 track
What did you do to put the 141 on it? Looking at this for my brothers Powder Special.
sdsnocop
1,441
2,192
Hot Springs, SD
A 141 1.75 track is an easy modification on that sled. The 1.75 lugs fit without changing drivers or grinding fins off the heat exchanger. To accommodate the longer track I relocated the skid frame back 2.5 inches. I redrilled the front mounting bolts 2.5 inches back and built a drop bracket that relocated the rear mounting bolts 2.5 inches back and 1.5 inches down. It bolts to the original rear susppension monting tabs. The homade drop bracket can be seen on the pictures in my post. I did not need a tunnel extension I just added a couple of pieces of alluminum to hold the snow flap back at an angle for clearance. Moving the skid frame back changes the front angle of the track on the snow similar to rolling a chaincase which improves performance in the powder. This is an easy modification that has worked very well for this sled.
Good Luck!
G
geberhard
160
Oxford, Mi.
Good Luck!
I am guessing the front mount at 2.5" is straight back correct? I would be interested to see some better pictures of your set up. I was under the impression the 141" track was 3.0 pitch . The 136" is a 2.52 pitch I thought drivers would have to be changed.
Idcatman3
MODERATOR: Premium Member
868
Idaho Falls, Idaho
Not all 141" tracks are 3" pitch. That is one of the lengths that happens to come in both 2.52" and 3" pitch. There are many good 2.52" pitch, 141" tracks.
sdsnocop
1,441
2,192
Hot Springs, SD
I will try to post some close-up pictures in the near future. When I redrilled the front holes I believe I cheated them a little lower but wished I went further down. I will verify for you. Also when I replaced the track I was not aware of different pitch tracks but must of gotten lucky. I will also get you the brand of track. My sled is in a storage unit untill winter. (however I did drag it out yesterday and rode 1/2 mile down the ditch and back in the 4" of snow we received this weekend.)
