So those of you who have tested giving it a little juice, did you have to supply it with much power or just barely tap the turminal to the hot wire to get it to start producing power?
Played with it today. I tried 2 regulator/rectifiers on a 2011 Pro. The regulator/rectifier would not stay excited without a constant voltage supply to the RD/DG wire. Also used different combinations of watt loads, no change.
Just so we are clear:
So you are saying you tried getting it to work WITHOUT the small battery in the circuit?
I saw a battery in your previous picture so I just want to be clear.
Just re-read this whole thread again, lots of great info. Here's my question:
On my '12 ES sled, I want to delete my headlight for venting, and run a Rigid or similar LED bar on my handlebars. I know I need to put a draw on the headlight circuit so I don't fry anything, so what exactly do I need to convert my AC headlight circuit to DC to run an LED? The light bar I'm looking at is 24 watts, probably around 1.5 amps. I'm also going to run a helmet light as well, preferably on the same circuit to draw some more juice. I am already powering my A/F gauge with a relay off my battery, triggered by the underhood DC acc plug, so I know there is power there.
Ok, so there is sufficient draw on the system with a battery to not have to worry about cooking a VR? I realize many people are running successfully without headlights, I just prefer not to run any risks with my electrical system. If this will work 100%, I'm all for it.
I do a ton of night riding in all sorts of terrain, so for me the more light the better.
