Thought I'd start a new thread on this issue and see if much has changed with anyone else's original vote on the engine poll.
First off I have a 12'. I originally had no issues with my engine with 1100 miles on it. That is where my vote went on the original post.
On what turned out to be my last ride of the season (not intended to be the last) with 2100 miles on my engine the Mag side Cylinder Intake Skirt broke off and went through the bottom case and broke the Reed area of the upper case. I was traveling down the trail just about to the good stuff when pow it went. Right around the 6400 RPM range when it happened. My primary riding is trees, so on and off the throttle often with wide open pulls under high load. When on the trail very seldom go over 7000 RPM. Over the trail racer stuff and the belts last much longer. I have turned my Oil Pump Up as far as I could without getting the top of the threads on the set screw into the nut. Have never added oil to the fuel tank which IMO does nothing for the bottom end and very little for piston lubrication. No benefit from doing so for the engine problem I had, again IMO. I always had a little worry in me wondering when my engine would fail. Thank the Lord I was in an easy spot to tow out. Just wanted to give an honest review on what I experienced that was not in a poll. I now have a 13' short block in my sled. We'll see it rips next year. Till then....
