N
A few guys were asking about this on the old forum and I did promise I'd put some pics up so here they are. Most guys will tell you that running pods will lose HP, which is true if you are sucking in hot air. This is my set up, it works really well on my sled. It is very easy to dissassemble and remove, basically two hose clamps. The aluminum intake tubing I used was 2 3/4" from Vibrant (http://vibrantperformance.com/catal..._1036&osCsid=d5878085cac3c0f7b31f849a5547fe9e) same as the turbo guys use. It fits 40 mm carbs perfect. I did have to trim the tubes a bit to make them fit where I wanted to but all in all it probably only took 1-2 hrs to build the system (measuring, cutting, testfitting, etc).
The parts cost about $90, not including the filters. Weight is slightly less than the stock airbox, maybe 0.5 -1 lb, but the main advantage is the cold air feeding the motor.
I use 10 degree angled Uni filters with a pre-filter sock (not shown in pics). I used the angled pods so that they fit under the headlight area, you can get straighter ones. I kept the upper tube as long as possible to keep the filters up in the cold air flow as best as possible, but they could be cut down if height was an issue. There are other ways to create different cold air induction points, I mounted mine in the headlight area because I wanted a bit of an "air scoop" effect (which really only happens at higher speeds on the trail or going downhill really fast ). Mainly I just wanted to maximize the cold air flow into the motor. I don't ride at night much so not having a headlight isn't a big deal for me. The intake could be angled backward behind the headlight, sideways, through the hood or anywhere you wanted really. Its just a matter of getting the right pieces and cutting them to length.
The drawbacks to the system are that you do not have a headlight, so riding at night is a little sketchy unless you use an alternate source of light. With no screens, more snow does tend to accumulate in the engine area. Keep in mind that I use this competely open system in spring riding, for deep powder snow I cover the holes with screen. You will likely need to play with jetting if you go with an open system such as this.
First pic is where they are mounted in the headlight area
Second pic is how they look under the hood
Third pic is a side view of the intake tube with carb
