'09 M8 bogs/dies when going to throttle
<edited to update status>
Ok, i was blaming the throttle safety switch, but I clipped one of the wires to the switch and it still did this yesterday.
After high throttle operation, if I come out of the throttle for a second and get back in it gently, the engine dies out, just like the throttle safety switch is telling it not to go. If I get off the throttle, it will idle, and if I let it idle for a few more seconds, it runs just fine when I throttle it.
It does it at the worst times, like when I've just climbed something and trying to get turned around, and bla... blaaaaa... Idle.... Then it goes. Luckily the snow was rather set up and it never got me stuck, but I could see how I'd be screwed in deep powder.
The sled is bone stock. Plugs looked OK when I checked them after the last ride with the SLP can, and I tossed the stock can back on it for this last ride.
Any ideas? Anyone else notice the same thing? I'm wondering about the fuel pressure perhaps, but not sure how that would do this w/o running lean all the time, or rich all the time.
I have messed with all the wiring harnesses, and they all seem fine. It never does this unless I'm bounding up something, at higher load. I messed with it across the flats yesterday and never got so much as a hiccup...
Strange that it will idle fine, but throttle kills it, then it's fine again with throttle after a bit of idling.
