Correct me if I'm wrong but that would increase the angle of attack of your track and therefore turn your RMK into a 'Doo trenching machine.
Seems counter productive to what the sled was built for. IMO
Did you simply drill a new hole, or use a different strap?I lengthened mine a small amount. No matter how much a cranked my preload on the FTS I always felt like there was too much ski pressure. For me it was a definite improvement, But...has anyone on Snowest ever performed any modification and then come on here and said the mod actually made the condition worse, reguardless of how ridiculous it was?
Thanks for the TS comments - would be a neat set up for sure. For your "mini wheels" did you just use an anti-stab kit? That sounds like a good idea even if for nothing else than (as your say) pulling off the truck (which is no joke with a pro some days).There is not much room to move down the front with the Pro rail but I installed the TS longer strap (with the rear arm kit) and have had no issues for a couple of seasons.
It is definitely set at max extension for fully bottomed rear and fully extended front. On it's own it is not a huge change though. I also added some mini wheels inside the rails in front of the shock mount to free up some HP. Sure made yanking the sled of the truck easier.
Jay, you are one to keep your sled for a while. The TS rear arm kit is awesome for adjustability for different snow conditions. IMO a good investment for the long run (and in case we get another year like this year).
With the adjustability of the EVO flt3 you can run almost any ride height pressure and still not bottom with proper EVO chamber pressure. Really allows for playful adjustments with the extended strap and the coupling adjuster will bring back your attack angle in seconds for a deep day (think next year)..
I did it on my 2013 but found I could get equal results by tightening front skid shock and running rear slightly softer with ski shocks set soft.
...I could get equal results by tightening front skid shock and running rear slightly softer with ski shocks set soft.
Exactly, I took the same approach with my 11 and 14, but I'm running floats and a zero pro FTS - still not the same 'playfulness' as geo described with the TS rear kit, but pretty easy to get/keep the front up. Know all about that, since I also own lots of doos. Poo stock track doesn't help with the issue, either. Have not had trenching issues at all, tho. With snow this year, wish I did...
Speaking of doo - they're offering an on the fly adjustable limiter this year - but for the opposite reason - getting the front end down. Doo's had easy adjust limiters going back to the revs - can't recall if the ZX had them. But not on the fly. Regardless, something like it would be a poor man's Skinz, or easy adjust TS option, for the pro.
Q on the side here: what is wrong since my sled is hard to turn around on the flats? Just wants to push straight forward. Just runners worn down?
Have adjustable limiter but set shorter, not longer.
That is the weakest performance point of the grippers. FWIW, does it push when you stand and put more weight on the outside ski in that situation - the pro will rail around with that ski loaded regardless of ski and with a normal shock/skid setup.
Either changed it with a different one, or drilled out the stock one?
I've been toying with this idea. To get any transfer (ski lift), it seems you have to run the FTS fairly tight. Any thoughts on if a slightly longer strap would allow you some lift while letting your run the FTS a little looser?
