I am in the process of swapping out my 154" to 165" track and rail, I also swapped my 2020 Fox QS3 Coil Over Shocks for 2019 Fox Float QS3.
While trying to re-install the FTS (Front track shock) Fox Float QS3 shock, the shock will not attach ...do to the limiter strap being crazy tight/taut, the QS3 Coil Over came right off the mounts with ease & with a looser limiter strap, so i released the air in the fox float QS3 shock and removed the limiter strap, attached the shock to the mounts and finally got the limiter strap back on and it is crazy tight with out any air in the shock, the limiter strap is on the loosest setting (while doubled) all part numbers match from 2019-2020-2021 for limiter straps, front arms, shocks for both 154" rails and 165" rails.
Should my strap be that tight?
Any thought or input on this would be much appreciated
