N
Hi Guys, New to the site. Just picked up a 2013 Pro RMK 800 yesterday. Im thinking if I cant off-trail ride this sled properly Im just throwing in the towel on off trail-riding all together. Coming from a 2004 skidoo 163" highmark summit that I hated with a passion.
But before I can even ride this Pro I have to figure out a issue my sled has.
Its got 125 psi compression per hole and aftermarket can and 1500 miles on the clock.
It starts on 2 pulls and immediately the digital gauge shows "9 - non" or something like that for a split second and then goes to normal rpm and stuff. Wondering if this is normal or a code I should check?
My sled Idles at 2500 rpm and my reverse button does absolutely nothing which are my main concerns.
It does not even try to go into reverse when button it pressed either....nothing.
I see a little throttle adjuster/idle screw on the throttle stop but doesn't look like it should be messed with so I haven't touched it.
One thing the sled does do is while warmed up and idling constant between 2400-2600 rpm the check engine light will come on for a second or 2 and at same time the rpms will drop down to 1500 rpm then the check engine light goes off and the sled idles back up to 2500-ish rpms.
Its almost like it wants to idle where its suppose to and trys for a second or 2 but cant.....
Anyone ever had this specific issue?
Oh and the brake light switch seems to be a little sticky once in a while but dont think that has anything to do with high 2500 rpm idle....
